sandpaper for Radius dishes http://www-.luthiersforum.com/forum/viewtopic.php?f=10102&t=3772 |
Author: | Robbie O'Brien [ Thu Nov 10, 2005 10:06 am ] |
Post subject: | |
Does anyone have a source for replacement sandpaper for the radius dishes? |
Author: | L. Presnall [ Thu Nov 10, 2005 10:10 am ] |
Post subject: | |
Robbie, try John Hall! ![]() |
Author: | Don A [ Thu Nov 10, 2005 10:18 am ] |
Post subject: | |
Robbie, John Hall gave me a source a few years back. These folks will put together whatever you need. I purchased 24" round with adhesive backs. I do believe they have a minimum order of 5 or 6. The supplier is Industrial Abrasives |
Author: | Tom Dowey [ Thu Nov 10, 2005 10:54 am ] |
Post subject: | |
Robbie, I have bought wide sanding belts. I bought them through woodworkingshop.com. A 25 X 60 belt gives you 2 radius dishes worth. |
Author: | Paul Schulte [ Thu Nov 10, 2005 11:13 am ] |
Post subject: | |
Mark Kett at guitar jigs. He has 50 grit paper that is one piece which is a plus. The 50 grit lasts a very long time. |
Author: | Kelby [ Thu Nov 10, 2005 12:15 pm ] |
Post subject: | |
Harbor Freight sells a 5-pack of 6"x48" sanding belts for $12. I cut two of those into 4 pieces big enough to cover the dish (when I lay all four of them out), and I glue them on with 3M spray adhesive. Cheap and effective. |
Author: | tippie53 [ Thu Nov 10, 2005 4:09 pm ] |
Post subject: | |
I have 24 inch disk with adhisive backed for $15. I have 80 and 100 grit. shipping is about $5 john hall blues creek guitars |
Author: | Sylvan [ Fri Nov 11, 2005 1:30 am ] |
Post subject: | |
I just got them from John. The quality is excellent and I highly recommend them! |
Author: | Robbie O'Brien [ Fri Nov 11, 2005 2:19 am ] |
Post subject: | |
Thanks for the info! |
Author: | tippie53 [ Fri Nov 11, 2005 3:27 am ] |
Post subject: | |
Thanks for the kind words Sylvan. |
Author: | Tim McKnight [ Sat Nov 12, 2005 11:13 am ] |
Post subject: | |
John: Do you have 14" discs in 80-100 grit available? |
Author: | tippie53 [ Sun Nov 13, 2005 12:42 am ] |
Post subject: | |
I have 22 and 24 inch widths. I may be able to get the 14 john |
Author: | npalen [ Sun Nov 13, 2005 4:06 am ] |
Post subject: | |
I use a 24" flat disc for trueing the archtop ribs and had always used pie shaped segments in the past to make up the 24" dia. It was quite a process to cut and glue the pieces in place & removal was no fun either. Bought a couple 24" discs from John a while back with self-adhesive. Oh so nice! Nelson |
